  • Configure the required SPBM and IS-IS infrastructure, which includes the creation of SPBM B-VLANs.
  • Create the C-VLANs and add slots/ports.
  • Enable IP Multicast over Fabric Connect globally.
  • Assign an I-SID for the IPVPN.
Use this procedure to configure IP Multicast over Fabric Connect for a Layer 3 VSN.
You cannot enable IP PIM when IP Multicast over Fabric Connect is enabled on the VLAN.
The IP VPN does not need to be enabled for Layer 3 VSN multicast to function.
The switch only supports IPv4 multicast traffic.
  1. Enter VRF Router Configuration mode for a specific VRF context:
    enable
    configure terminal
    router vrf WORD<1-16>
  2. Enable Layer 3 VSN IP Multicast over Fabric Connect for a particular VRF:
    mvpn enable
    The default is disabled.
  3. Exit to Global Configuration mode:
    exit
  4. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface vlan <1–4059>
  5. Enable Layer 3 VSN IP Multicast over Fabric Connect for a particular VRF:
    ip spb-multicast enable
  6. Optional: Enable IGMP version 3:
    ip igmp snooping
    ip igmp ssm-snoop
    ip igmp compatibility-mode
    ip igmp version 3
    IGMPv2 at the VLAN level is the default setting, with no other configuration required. You only need to use these commands if you use IGMPv3. You must enable SSM snoop before you configure IGMP version 3, and you must enable both ssm-snoop and snooping for IGMPv3.
    For IGMP Snooping, ensure that the IGMP version used by multicast hosts and other devices in the network is the same as the IGMP version configured on the IGMP Snooping VLAN, or that you enable compatibility mode.
  7. Optional: Enable the IGMP Layer 2 Querier address:
    ip igmp snoop-querier-addr {A.B.C.D}
    If the SPBM bridge connects to an edge switch, it can be necessary to add an IGMP query address. If you omit adding a query address, the SPB bridge sends IGMP queries with a source address of 0.0.0.0. Some edge switch models do not accept a query with a source address of 0.0.0.0.
Configure IP Multicast over Fabric Connect for a Layer 3 VSN:
Switch:>enable
Switch:#configure terminal
Switch:(config)# router vrf green
Switch:(config-vrf)#mvpn enable
Switch:(config)#exit
Switch:(config)#interface vlan 500
Switch:(config-if)#ip spb-multicast enable
